While overdrive is a great thing to have, too much of a good thing here is not beneficial. Most engines do not care to be "lugged", In my experience, trying to run anything tighter than a 2.7 ratio overall in OD is fruitless, using a higher stall converter just compounds the problem. If your engine is modified for increased performance it will also reduce the low rpm torque to the point that you need to give it more throttle to maintain speed-which the TV cable "reads" as needing a lower gear/unlocking converter.
There are mods you can "do" to keep the trans in OD at speed, but before starting, could use more info on car:
1, Make/Model/Year of car:
2, Engine Type/Size/Carbed or Fuelie/Mods done:
3, Rear Axle Ratio/Tire Size
4, Transmission Model(ie:700R4/200-4R/AOD/A500/A518,etc.)
5, Primary Use of Vehicle:
If you want a correct answer, we need correct info.
Kevin.
