3" DP, E-Fans, UltraFlow Muffler, K&N Filters
DJackson1357
2 Piece Aluminized 3" Downpipe with ported elbow and dump. $150
3" direct fit catalytic converter with less than 5K miles. $100
3" inlet 8" long K&N Filter - has a small hole on the side of the inlet area for an air temp sensor, needs cleaned / re-oiled and some of the mesh is damaged. $10
3" inlet 14" long K&N Filter - Needs cleaned / re-oiled. $10
Dynomax Ultraflow 3" Muffler - Offset/Center orientation, part #17221. New in box. $30
LT1 dual fan setup - Originally came equipped on a mid 90s Caprice, but was modified to use in a G-body by slightly trimming the lower fan shroud. Both motors work fine and the unit does pull a lot of air. The car it was on was scrapped so I no longer need it. Does not include harness. Also have the Cutlass steel upper radiator support with brackets to mount the fan. $75 for fan only or $100 with upper support.
Spal 9" Puller Electric Fan Part# VA07-AP12/C-58A - Never been used. $40
3rd Gen F-body (Camaro / Firebird) rear coil spring isolators - Can be used on a G-body to allow use of F-body rear springs, which can be cut for desired ride height. $15
All prices are plus shipping. Pictures are posted here --> http://s273.beta.photobucket.com/user/DJackson1357/library/
If interested in something make an offer, all I can say is no.
