So THAT's what it sounds like when you blow off an intercooler hose
:redface:
After being out of country for a couple weeks, I finally finished installing the 6265
I ran the WG actuator all the way out until it was just shy of the WG arm and went out for a test drive.
I maxed out the fuel in the chip and also the alky until I know how this thing is going to boost up. I'd rather be fat then lean.
I slowly rolled in and watched as it built the boost....up....16....17....18....POOOOOOSSSSSSSHHHHH!!!!!!
Scared the crap out of me!
Fortunately all it was was one of my lower IC pipes. I didn't clamp it tight enough after reassembling while jet lagged so the bugger blew off and gave me a big ol' "HOWDY STUPID!"
Since it was dark out and the hose clamp was MIA, I nursed it sloooooowly back home (about 1/2 mile) and fixed it.
Up and running again and I did a couple TNT runs. Tightened the WG rod a turn and am making about 21 lbs of boost and the O2's are well over 800 with zero KR, so some tuning will make even more power.
I also am running the actuator "tuner style" without the RJC controller for now.
It does creep a little, so I need to port that WG hole a little more liberally before adding any more boost, but MAN does this thing pull:biggrin:
Can't wait to kill something.:biggrin:
