Here are my chassis suspension points and measurements up to this point.
Wheelbase: 108"
Percent weight on rear: 43%
Car weight: 3140 lbs. w/driver
Rear tire diameter: 29.5"
Front tire diameter: 26"
Pinion yoke angle: -1.5 degrees
Driveshaft angle: -2.0 degrees
Trans output shaft angle: -2.5 degrees
Top axle bracket: 0 x 20.81"
Bottom axle bracket: 0 x 10.56"
Top chassis bracket: 7.5" x 19.94"
Bottom chassis bracket: 19" x 11.5"
Instant center length: 61.9"
Instant center height: 13.6"
Anti-squat: 104.2% Using an estimated 22.79" CG location.
The height from the floor to the middle of the front lower control arm bolt is 9.125". Floor to front crossmember clearance is 6 7/8".
I suppose next will be to level out a floor area and search out some scales.
Here's a pic of the front lower control arm with the ride height that I picked for the front end.
Is it preferred to have the lower control arm parallel to the ground?
Front end extension travel has been limited to 2.5" to 3". The stock rubber bumper actually starts to take on the load of the spring and tire/wheel about 1" sooner.
Don,
You're probably going to want the IC around 34"-38" with around 100% AS with the LCA's perfectly horizontal with the ground. The IC is pretty long right now and may not load the tires hard enough and keep them planted. It's not too bad right now if you can't get it moved back, tho.
Since you have the frontend tied down the tires won't have too much bumpsteer so I think your front arms should be fine.
KS
In my car we were thinking that 42" was to short. In lowering the car we were trying to get the LCA more parallel with the ground which I believe they are now. This would've increased the IC arm's length? I know it definitely helped keep the front end down.
What end of the scale is your front shock set at? It was recommended to me to start out on the soft or loose end of the extension adjustment range. I'm using single adjustable QA1s in the front.That is what we had at the time. What doesn't seem right? I know we ended up setting the HR rear bar offset based on the wheel weights and later rescaled the car to set it up. Which we also spent time squaring the rearend setting the front end alignment and checking pinion angle.
Car is 100# lighter now and we went back to a 28" tire that fits the car better. I did this when we put the Wolfe Racecraft UCA and LCA on with end links. Since we bent both UCA's and trashed every rod end in the set. I switched to Paul's new insane UCA and LCA with the teflon 7/8" rod ends VERY nice stuff and should hold up to what we are doing now.
I've also switched all of my front suspension to the TRZ stuff. Right now I have the front control arms with stock spindles and steering. After I hit the wall at Norwalk in 2007 I also had all the QA1 shocks rebuilt and re-valved. The valving on the QA1's is not ideal for our cars and it seemed to be a worth while investment. IMO the front suspension as important if not more important than the rear suspension in getting a car like this down the track. We by chance found the messed up Wolfe suspension pieces and were having no issues with the 60' or car handling. I wrecked the car over a bad right front shock and if you change my front shock settings one click either way the 60' will go to hell fast. My car has always been VERY sensitive to front shock and suspension settings.
That's good news to me. Then depending on how hard my car launches, my long IC might be the ticket. My rear tire setup is the same as yours except for the diameter. I'm trying out the 29.5" in an effort to get better traction. Also, in the quarter mile, I was running way too high on the tach by the finish with the 28s.The Ford 9" housing really raises the UCA shortening the IC length quite a bit. As a result my car can hit the tire really hard and at the weight and power we are at it will KILL tire sidewalls. I run a 28x10.5 stiff sidewall WITH tubes. Lowering the car and tucking the 28's in under the body also helped take some "hit" off the tires to keep the front end down.
I was shooting for around 1.5" too. I didn't realize that oem bumper compressed and allowed so much more additional travel. Depending on how things turn out, I may still change that and lessen the travel more.I have 1.5-2" of travel in the front end
What I feel is off is the more weight being on the right front and left rear corners. My research, so far, suggests you'll get better equal loading on the rear tires at launch by setting up static with more weight on the left front and right rear corners.
With the old suspension I was also killing the sidewalls on the 28s on a hard launch tuneup. The front end was liking to get too high also. The IC before the suspension upgrades was probably very close to what it is now, so I would have to figure that going shorter with the IC is not what I want???
One thing I'm trying, don't know if it has any merit, I have the left front run out of travel just a tad before the right front. My thinking was, hey, it's an adjustment. Why does the front end travel have to stop at the same time for both sides? Maybe there's an advantage somehow to let one side or the other run out of travel before the other. I thought, if the left front gave up travel before the right front, then overloading of the right rear could be controlled. Is this a valid assumption?
The ride height in the rear is very close to what it was with the 28s. There was room to fit the 29.5s in there without having to raise the rear. It's tight, but there's room. The rear may be higher now by about 1/4", if that. So the IC hasn't been messed with much with the tire and suspension changes.If you have to jack up the rearend to fit the 29.5 you may be better off with the 28's at least I was. To get them to fit you have to tuck them in under the body and lower the rear. With a stiff sidewall MT I could throw everything at it and they would dead hook but the car would wheelie. With the 28's I can throw 90% at them and sixty in the low 1.30's and never lift the tire. We started playing with the MT 325/50 DR. Last time out we went 8.68@163 with them and a 1.37 60' on a mild launch. With some tuning I think I can get them in the low 1.30's. I think Dave Fiscus pulled a 1.27 with them at Norwalk!
I understand. Good advice.Who knows try it? IMO once you get it all together and everything plotted out real nice and take to the track you will likely still have to make adjustments and changes to get it right. The nice thing about a plot is you at least have a baseline of where you were at. What looks good on paper doesn't always work out on the track.
