you could always just call the number
what i see looks old old school early 2000s
atr stainless ext dp with hks gate (single port hookup no less)
looks like a 71-76 gtQ turbo with the 70AR 4in 2.5 out comp housing , (i have similar DP and turbo setup on my 86)
from the black powder coated inlet pipe im guessing cas V2 FMIC still running the 2.5 inlet pipe and two piece up pipe , (i had same setup on mine for years )
valve covers are center bolt possibly m+a alum heads,
stock TB plenum (most likely ported) , stock Maf ,stock headers , stock cooing fan
looks like an alum end tank radiator (not an OE)
don't see a sway bar hanging out back so i'm going to guess its a wolf bar under there
Stainless steel single shot exhaust might have the muffler where the cat is
still an 8.5rear with drum brakes , aftermarket box tube control arms
front frame braces
145 speedo, radio top pod
