3.8L V-8 eater
- Jul 22, 2006
Hi, to all
I just finished putting the engine in my car and got everything buttoned up and finally reached the point where I could try and start the car. This was an engine swap from one Tr to another and I had nothing internally taken apart on the motor just pull it out of one and drop it in another. Should also mention I did this cause the motor I put in was just rebuilt early this year by Hye Tech in CA.
Due to my lack of experience I did not realize till now that a oil pump could loose it's prime from setting even if not taken part... Sooo I start the car and it sounds like a gremlin is inside the motor with a hammer :frown: I shut the car off looked over everything thought about what it could be. Called a friend of mine with GN who was coming over anyways and we realized there was no oil pressure.
So... now that I know I had no prime I pulled the buttom of the oil pump off to pack it with vasiline to get a prime. When I pulled the cover off one of the gears fell out which I realize just rides on a stub and the other is attached to a shaft that goes up in the oil pump and it fell part way out not all the way.
Sorry to be long winded cause I'm just getting to the questions
I have attached a couple of pics to help out!!
1. Should there be scratches on the bottom cover from the gears turning inside the oil pump????? As you can see in the pics they are there.
2. Should the gear that attches to the shaft have fallen part way out or should it have stayed put??????
3. Is it ok to pack with vasiline and put back together to see if it will prime???
Thanks!!!!!
Thanks!!!!!
