joe_schindler
Living better with carbon
- Oct 1, 2001
Be careful, removing material can effect oil pressure.
How?
If you increase the space between the rotors and the cover. There's a tolerance there.
hogwash , no way to alter the clearance by sanding the adapter on a flat surface (i like glass) . you're restablishing a flat surface to a surface that should be flat without gouge marks from debris, the gasket selection decides the final clearance.
I think you guys are both thinking of this correctly; but from different sides.
If you sand (shorten) the gears; you create more clearance. If you sand the adapter; you remove some clearance that shouldn’t be there (but if the gears chew it back up; you don’t gain much); but the bottom of the gear is probably bad also. I might not have been real clear on everything.
Not much you can do about the top of the driven gear or the top and sides of the case.
I think my next engine is getting a FWD cover.
