Ok I won't even begin to talk about my frustration.
I was listening to the motor it sounded kind of funny so I started looking for issues. I found a very small amount of brass like materials in the oil so I pulled the oil pan.
There I found small flakes no large amount, so the damage may be minimal. At any rate, I haven't taken the rod caps off because I can't figure out how to do it from under the car without damaging anything.
Attached is a photo of the second center cap and I am wondering what would cause this / crank walk. Not to mention this is a brand new motor with less than 2k in soft miles. Soft miles meaning nothing above 14 lbs. I did all of the assembly but purchased everything from a competent vendor. It looks like I did something wrong. Help appreicated, I'll report back once I get the rod caps off. Although I have never experienced a spun bearing, I have a feeling that may be my issue.
FYI the wear seen in the photo is on the side facing the rear of the car.
