SS/GN
- Jun 30, 2005
I've never opened the oiling holes in a Buick V6. I have also never had a problem oiling even 1000+hp engines, either. I don't like the idea making an already weak block weaker. Most of this kind of stuff is just trying to out think things. I DO radius the oil passages in the block and timing cover, but even that is probably not doing much, but at least it doesn't weaken the block.:smile:
Interesting,and do you use a high volume kit with these mods?.Good info here and I agree with the radiusing.I find it eliminates sharp edges and small casting flash more than anything.I agree with the too much thinking ,however this is a great forum for bouncing ideas around.Thanks for the input..appreciated
Kevin
