- May 26, 2001
Thanks for that last piece of advice Nick, you're always good for a gem or two. I'll likely order the adapter that Mach0.8 recommends.
Nick, what pedal ratio do you shoot for? Any pearls of wisdom about getting the pedal set up?
What bore size works best: 7/8" or 1" or others?
Wilwood recommended an 1-1/8" bore MC. Rick Elam at Baer Brakes said 1" should work fine too.
I am not interested in manual brakes on a street driver. With more pedal travel it gives a slower response time for a panic stop. Some one familiar with operating a manual brake vehicle may not have an issue. I would not put my wife behind the wheel with a manual set up on a GN
To answer the question about ratio, seems like the stock GN PM pedal works fine with this conversion. I would never use an adjustable rod on any car unless it is just for testing and fit. Then I would weld it so it cannot move.
On the race cars I have converted, it is really best that the stock rubber flex hoses are replaced with stainless lines. I love the solid brake pedal feel at 140+ MPH.
Based upon info here, I just ordered a S-10 MC to try on a local GN. I will modify the stock push rod to try and simplify this job. Should be done this weekend. [Any interest in a working PM? Hope the owner reads this thread so he will know about this before he picks up his GN!
