blackgn231
Money pit
- Mar 28, 2007
I know this is dumb to say but when ,I rebuilt my motor, I never did check the bearing cleanness the machine shop said the crank looked good so ,I put standard bearings back in but now I have read the Buick cranks were some time ground at the factory, so now low oil pressure had run about 40 at 60 mph but now it only goes to 30 and some time 20 at 60 but no knocks or lifter tap, I have a VDO gage and did replace it after the motor was put back in but did not replace the sending unit did rewire all the gages so not sure if that’s the problem ,what do you guys think? I was thinking about dropping the pad and putting some new bearings in but that may be harder than it sounds pulling the motor may be my only hope any help you guys could give would be great hate to pull it but if that’s what needs to happen then it does so anyone?
