Tim Cucci
- May 24, 2001
My 109 block has been modified with the larger 2/3 oil holes in the mains. I understand that a HV oil pump should be used for this application, a machinist told me that I should have a Deep Oil Pan also. I have researched several threads, articles, engine tips but I can't see where I need a larger pan.
My engine is currently ready to be put back together standard bottom end. 10/10 stock crank, ARP studs and rod bolts, Stock Pistons, Rev X Roller Cam, P/P iron heads, Speed Pro 6-7120CH rod bearings. Bolt ons such as TA49, THDP, SMC Alky, V4 IC.
Do I really need a deep pan??? Oh Yea The main bearing shell oil holes are drilled to 5/16" and the main oil holes are drilled to 3/8". Is 5/16 the correct drill size for the bearings. ???
