7500What are your rev limiter settings inside the TR6 box??
SignUp Now!7500What are your rev limiter settings inside the TR6 box??
TurboBob said:Its not a code 13, the run LED is blinking steady which indicates the module is running in base timing mode. If the base timing switch is not on in the module, then the EST output from the XFI is not being received by the module.
If you had one of my 2-steps installed before, make sure the white wire is properly reconnected.
Bob
CGASTON said:I will check the EST wiring and check continuity.
Sounds like a great idea![]()
now is not a good time to call.
the blinking code in the one video is a 31, not a 13, and then engine is not running at the time, so I assume you were adjusting the cam sensor at that point....
Bob
Cal/Bob,
I verified the continuity of the EST wire tonight as well as the CRANK Reference LO and CRANK Reference High. I verified continuity of the three from the ECU to the weather pack at the ignition module. Everything was good.
So with the TR6 in mode 4, I check the timing one last time time. Still the same. I then increased the rpms ans check the timing; it still read 10*
I changed out TR6 with an stock ignition module and the car wouldn't even start. It would crank and crank and try to fire. Then all of a sudden, she would back fire loudly out the exhaust... Sounded like I was shooting a gun in my garage.
I am starting to not like the fast and tr6, cause of this non running issue. Anyone willing to help or give ideas, please let me know.
Clinton
The backfire sounds like a cam sensor that is just a tiny bit out of adjustment. I've had the same issue a couple of times and it was always corrected with a tweek of the cam sensor. I set mine and then tweek it based upon how well the car restarts. My car ran fine for a couple of months but would backfire on startup every once in a while like that and this fixed it.
It could also just be backfiring from fuel load from not starting properly too. Just thought I'd offer my .02.
Good luck with your gremlin.
the cam sensor is not the issue. the tr6 is not setting any codes when running. The blinking run light means that its running at base timing (as you have verified).
running at base timing can be caused by 4 things in the TR6.
The base timing switch being on (its not)
The EST signal not being received (you checked continuity)
The Bypass signal not being received
The EST signal being "wrong" (I.e. timing wayyy out of range)
The stock module not running is indicative of some issue with the EST, since if the bypass were disconnected the module would run in crank mode.
The diagnostics for the EST and Bypass are not enabled in the current TR6 software, this is the first occaision where they have been needed.
I'll look at getting them activated this weekend.
Do you still have your stock ECM? you can plug it in, even without a MAF or all that and the car should start and run. You can then validate that both the stock module and TR6 start and run.
Bob
Hi Clint, I'm in Casa Grande and have a tr6 that we could swap out, if that would help.
I hear ya on the dynamite, yeah I can take a ride down. Whats a good time for you?That would be worth a try..... I really want a stick of dynamite sometimes.
Wanna drive to Sierra Vista?
turbotroy said:I hear ya on the dynamite, yeah I can take a ride down. Whats a good time for you?
Pm sentTomorrow I may go watch Test-n-Tune at SIR in the morning. Have to check with the boss to see if she wants to do anything tomorrow afternoon... PM me your number and I will give ya a call tonight when I get home from work and speak to her.
Sent from my iPhone using Turbo Buick
Cal/Bob,
Clinton
