SignUp Now!I checked coolant level and it was fine. Oil looks clean too, maybe the exhaust is restrictive?223* on a 75* day.......just driving around.....AFTER repeatedly hitting 25psi on a hot air with no alky or E-85....?? Smells like a more serious problem.....time for a coolant level check, compression check, plug check......possible "stretched" head gasket or worse...??
I had a spare o2 in the trunk, so I removed the old one which was black, and installed the new one, I backed the Allen key on the adj fuel regulator out 1.5 turns, reset the ECM and the o2 code was gone and the int was 128ish and blm 130ish at idle. Just gonna let it sit until I can get the 4an fitting to female 1/8 to check the fuel pressure.Make sure the o2 sensor is plugged in. I'd swap back to the stock fuel pressure regulator until you get a fuel pressure gauge installed. Reset the ecm (unplug the orange connector on the positive bat cable) Then see where the BLM is.
I checked most of them, how would you put a zip tie on the line that goes under the turbo? Or even the one on the back of the intake behind the turbo?Nickel and dime is an understatement....lol. Good plan on the fuel pressure. Did you check all the vac line routing?
Only if you're a quitter.....Step 6, pull out Hotair motor and convert to Intercooled.![]()
