code 23 is the MAT could be cause by having the key on with the intake tube off, make sure the mat is plugged in
code 31 wastegate actuator solenoid, can be found by following the 3rd hose off the Y tee back to around the drivers valve cover, next to the brake booster, make sure its plugged in and the wires look good, clear the codes and see if they reset, if they do then you can start the diagnosis process for each code. CLT temps are high, recommend cooler thermostat, and the INT and BL indicate your lean, gotta get that fuel system upgraded, but for now check the fuel filter, ah heck just replace it, there cheap, then you can check fuel pressure, at idle with vacuum line off regulator, should be set to 43psi
