Step 6, pull out Hotair motor and convert to Intercooled.![]()
Actually it would be easy to do that if you don't understand how to think and just want to do a "bolt on build".
SignUp Now!Step 6, pull out Hotair motor and convert to Intercooled.![]()
It's orginal, not hot wired yet :/ good news is the waste basket(as my gf calls it) waste gate is in! Sucks that it gets dark early now lol, I have the itch to throw it in and start tuning!BLM of 150 is pegged out from a lean condition. Vacuum leak, pre o2 sensor exhaust leak. I'd also crank that fuel pressure up to 43-44 vac line off to start with...that may also help those BLMs...but you need to find the cause of the high BLM BEFORE you try to go wot....what's the status of the fuel pump? Is it new? Original? What brand? Hotwired?
i wouldnt be surprised if u have a couple issues. find someone with a known good maf or send yours to someone. you also need to check for a cracked ex manifold or an intake leak. thats where i would start. my car didnt run worth a damn for 2 yrs. then after i finally got it runninggood the module and coil crapped. fixed thst and now the trans is busted. dont feel bad. i'll hhave close to 17k in this car. no reason for you to feel like you wasted your money yet lol
