What are most of you guys that are in the 10's or faster, running for Target A/F ratios ? I am running off a setup that was done by the previous owner, but I want to compare it to what's working out there. Most of the settings are around 11.0 to 11.5 to 1 A/F ratio. The timing is at around 25 - 26 deg for use with 118 octane. What should my target EGT be at the top of 3rd gear...1550 to 1600 or so ?
Thanks for the help
Regards, Clem
Thanks for the help
Regards, Clem
