Steve I just stumbled upon this.
Ttype6 do not hog all of these up. I like your quadrajet comparisson. I had a 780 on my 67 GTO & loved it once it was set.
There is one thing after reading this I didn't see brought up at all. All these failures......... are your proprtioning valves the new re-call with brass or do you have the old Iron units on there? You know the ones that deteriorate on the inside? Turning your oil that nice shade of dark brown or black? The same oil that attacks the glue on the inside of the ACC ball & allows the diaphragm to fail? The same debris going thru the power master unit itself?
I get a call at least twice a month. This is the 3rd acc ball in 6 years, get me a vacuum brake system.
Did you check your proportiong valve to see if it was replaced?
No it is original.
Your oil almost black?
Yes.
Would you consider changing that & getting a new ACC ball?
No the Power master is Junk I read it all over the internet.
Every one of my personal Buick's & I have 1 or 2 is running a power master.
I really can not belive that a business that sold this as a full warranty unit wouldn't take it back.
I really think some one needs to get Richard Clark to chime in here as he likes playing with these alot.
I did not know that the Prop valve contributed to the PM's demise. I knew it was a problem in cold climates where the roads were salted.
Maybe an order is in the works.
