That's the latest version. You can try and make a change to see if everything else is up to date. Here's how:
key on engine off for this experiment
open the data tab, and notice the bottom two rows of the BLM table. I can't tell you what cell does what because I run Extender chips, however, pick a cell, and double click in it. This should pop open a small window with that cells's value displayed. Double click inside that little widow on the value, type a new value close to the old value (I.E. change a 128 to a 127). Press enter.
Did it take???
If it did you're good to go. Now all you have to do is figure out what cell controls what, and make your desired changes.
BTW, if all this works you should be able to make changes with the engine running also.
