- Feb 18, 2006
A picture is worth a thousand words.....
Thoughts.....
Rick
Thoughts.....
Rick
SignUp Now!Same here Rick. Bearings are very nice. Most likely just in need of a valve job. This translator pro is new to me though. So a bit of learning curve ahead on that one.Small world, glad he found someone good. It is beyond a doubt broken down filter media. Somewhere down the line there was some cheap filters were used. Bearing in this one look ok. Same thing, a little dirt went through but no copper. Thank the engineer that put the little flapper in the screen.
Rick
........ It is beyond a doubt broken down filter media. Somewhere down the line there was some cheap filters were used.
Rick
Wix is a good paper element
I cut all my filters the Wix is a nice filter better than AC and Fram
Napa's gold filter and WIX are supposed to be the same. Is yours standard or gold?
I loaded the engine tonite and the wifey is taking it to the machine shop after work Thrus, looking things over again John took real good care of it.The filter debris stuck the the screen was prolly from 2 owners ago. I know John never used garbage. The little flapper valve saved it from starvation.
Rick
Was this a fresh rebuild? could it be shop rag lent? maybe from just upper end work
