In my mind I am not sure you can blame anyone other than lady luck on this one, but you can make your own calls on that.
Mike
X2 !!! hit the nail on the head!! **** happens !!
Mike
I spoke to Dave and he leaked the motor down last night. On a stone cold motor it is 8% across the board, so no blow head gasket or breakage. Plugs say the tune up is ok. If he pours water in, it comes out the back of the block where a freeze plug used to be. You can see in the video where the water comes out and the car gets loose. In my mind I am not sure you can blame anyone other than lady luck on this one, but you can make your own calls on that. I only know he told me the motor runs fine and the car is not bad so he will be back out soon. Like Billy said "don't kill the messenger" but my info came right from Dave, not an unknown party. And V6 your right, it was on a mission
Mike
Mike
Jason your right, especially with Cometic gaskets. But there is no signs of detonation or lean conditions, things are OK on the log. I think it was just a "racing thing"
Mike
FYI, You can lift a head and have good seal on a leak down with the right head gasket. Ask me how I know.
No matter what, I'd let Dan look it over.
We must all be crazy trying to get over 3 horses per cubic out of these 109’s.
More like >3.5 HP per CI..
There are some ways to make it last longer if you do lift a head during a run but that is a conversation for another day..
In the end you still have to pressurize the coolant to a point where the plug pushes out.. They don't just come out.
My buddy and I once popped a freeze-out plug while we were idling in a Krauser's parking lot years ago. No forced induction and not overheating; we had just been cruising around and decided to pull in to get a drink. We hadn’t even turned the car off when we heard water gushing from under the car while we were getting out. Coolant temp was fine; the damn thing just worked it’s way out. We were not sure of the exact cause. This was on his 1970 Monte Carlo with a 350 street motor, nothing fancy. We had never raced the car and had just been cruising around that night, not doing anything to generate any amount of pressure greater than the stock coolant cap would allow. What Chris says is definitely true, if you flex the hole it'll work it’s way out.
Art.
Or maybe that 109 block is flexing a bit at that power level..
