how much time do you have on it?thought it was a newer buildNo issues at 7200
SignUp Now!how much time do you have on it?thought it was a newer buildNo issues at 7200
hmm,interesting.the ones i have been in were soft till higher rpm (overcomed by transbrake)but the turbo and cam has alot to do with the setup.Not so much.. real real treat in the street with a smaller motor
Kinda cool. Because this is exactly my combo.If I wanted to go fast and have reliability, I would build a high compression off center S2 (4" bore) with 3.4" stroke. That is the best of both worlds IMO.
Your car is a well-known Rock Star in the buick world.Kinda cool. Because this is exactly my combo.![]()
Thank you. But let me correct my last statement a little.Your car is a well-known Rock Star in the buick world.
You argue like a Democrat. If I don't agree with you,your open mind tells you that I'm wrong. If the laws of physics don't agree with your open mind,the laws of physics are wrong. If the smaller engine produces less power than the bigger one below 5,000 rpm,the dyno is closed minded.if you cant have an open mind.. never gonna grow
ive spun them to 7200/7500 rpm stock stroke,and had a combo that would spin 6600 to 6800 rpm all day.the destroked stage stuff 8500+,a destroked 109 will be limited to the block itself like all 109s when that power level is reached it will be at a higher rpm.there are ways to make the power sooner but that rpm window opens alot of options with the turbo and converter.If using a 109 block, small displacement-short stroke, what would be the RPM limit?
A 3.5 stroke on a big block is a short stroke motor. They are big bore short stroke engines with 18 degree heads with over 400 cc intake ports. But I see where you are coming from, I agree with a bigger motor making more power if you can feed it the airflow needed to make power.The engines in the pro stock community are 500 cu. in. with a 3.5 inch stroke and they rev to 12,000 rpm. Someone needs to tell them that they can make more power with a shorter stroke.
its why i asked what turbo was being usedif you can feed it the airflow needed to make power.
I honestly could care less about your theory and law of physics ..
and who gives a shit about if it makes less power at 3000 or 4000 or 5000 rpm ...
You have a lot to learn my friend
An emotional person has a hard time dealing with facts,then he attacks the character and mental capacity of the person on the other side of the discussion as if that has anything to do with weather or not a statement is true. He laughs and ridicules the other person. The emotional person then accuses the other person of being emotional. You definitely do argue like a Democrat.I find it hysterical that the most emotional people on this thread have no real world experience with this setup
agreed but that is all about power management.it seems everything makes power now, the real success on the street is in power management.Food for thought .. some of the FASTEST REAL street cars in the world AREN'T running 500 CID prostock motorsor 700 CID mountain motors ... actually many are running small blocks .
