Mike T
- May 3, 2013
Not sure how to point out what I believe is the obvious but here goes.....
Lets say we use the same top end on three different short blocks. Top end would consist of Champion irons and a roller cam that pulls to 5500. Our 3 short blocks are destroked, stock stroke and stroker.
The engines are all ran at 20 psi and to a max rpm of 5500. I do not see how it is possible for the shorter stoke (smaller ci) to out perform the longer strokes.
At the relatively low rpm that our engines typically operate piston speed and crank centerline wouldn't even factor.
Get into the 6k+ rpm territory and sub 10 second power maybe the short stroke would be something to consider.
