Directions for PL hook ups
jcawley3
does anyone one have directions for connecting a scanmaster to my Powerlogger.... also how to make the powerlogger read my boost.
I need this written in "Making your PL connections for dummies" style. Thanks -John
If you have a I/O connection block? 1- connect wideband analog 2 output
2-connect MAP signal (boost)
3-connect EGT
4- ground
5-l4
6-+5V
7- scanmaster connect white wire(with upgrade chip for scanmaster)All I use is the wideband,MAP, and scanmaster.
don't connect the 5V or ground connections to anything. They have very specific limitations.
thanks...I'll have to leave it to somebody else in fear of messing something up......
Too bad you're not in my neck of the woods.
the connections are no big deal, just follow the diagram.
Bob
beige wire goes to powerlogger one end and the other to the I/O connection block
ok....I printed all that off...hopefully he can make heads or tails out of it...thanks -john
