This last weekend netted some great new numbers for the car.
5.80@126.2 mph, 1.37 60'. The car was a dream to drive.
I can officially state that the car is at least back to the same performance level I was getting with the smaller turbo, with the mph being much better. There is still some tune left to throw at her.
The key adjustments to getting the car over the hump was dialing in the boost controller and playing around with the rear tire pressure. It wasn't any more sexy than that. The shock, sway bar, alignment, and spring settings have been unchanged since the last major suspension upgrade work.
The boost controller is leveling the boost at 200-210 kPa (14-15 psi) for the 1-2 shift and the max boost level for the rest of the pass for this last test & tune was 290 kPa (27-28 psi). Still a couple more pounds to throw at her, and with the performance increases I've been getting from just a .5 psi increase in boost, I don't think the car will handle it. We'll give it try anyway. :biggrin:
The tire pressure turned out to be very important. As was suggested by some, I started out by raising the rear tire pressure to 10.75 from 9.75 I had been using for quite some time. The results were disasterous, if not downright dangerous. I had a very big problem getting the car to hook throughout the whole pass.
I then lowered the tire pressure to 9.25 and immediately noticed a big difference in tire slippage, stability and mph. I then dropped to 9.0 psi and finally 8.75 is where it's at now.
A video of a latest pass with the car.
YouTube - Spooling a 91mm Turbo
