Works well on a fast car i can see.
What would this equate to in the 1/4???
Joe
Around 10.70s I would guess. Starting small, expect to be changing my sig a little later this year as I start to turn it up.
SignUp Now!Works well on a fast car i can see.
Joe
The starting calibration was quite good, very good throttle response over what I was used to. Currently just using one 3 bar MAP, will add the 1 bar later on.
Yeah, I'll be joining that EBL thread...
Nice tpi, i love those intakes. Lots of low end. I've built a tpi vortec 350 with a crower high lift cam, headers and supporting mods for a tow rig.Both the SFI-6 and the EBL-P4 share the WUD (What's Up Display), and I was greeted to my EBL-P4 when I got home from work a few minutes ago. No pin changes, no nothing, just drop it in and go, as it uses the original harness. A true plug and play. $530 shipped to the door, unlimited tuning. Since the two systems offered by Dynamic EFI share the WUD, I will add some video's to this thread in the near future of how to use it to tune the engine. Here is the EBL-P4, and the engine it will be controlling. I'll have the EBL-P4 swapped in a matter of seconds into the GTA (SFI-6 is just as easy to install into any Grand National), try that with any of the aftermarket ECU's out there...
i would have routed the belt differently to get more grab on the alternator pulley
from crank , around tensioner , under waterpump , around alternator, around PS, back to crank
the belt will have more contact on the alternator pulley (wont slip belt loose at rpm)
and it eliminates the long run of belt from crossing side to side in front of manifold
software looks like playing pong on atari![]()
How would you know? Is that your down time, Atari...?
I played Atari when I was a young boy![]()
Looks good, glad you are making progress!
I have the classic ebl, bbc tb, n2o, 10:1 comp, large comp cam, etc. When it first came out I bought it. Loved it ever since. With the improvements since then, I can't wait to get it for the Buick.
