CuzzinOlaf
- Jul 9, 2013
I took my car to get Dyno'ed this weekend with the what is in my sig. On a fairly conservative tune at 27psi on a STOCK bottom end it put out 501hp at the wheels. As tempting as it is to try and get more I don't want to push the car. No knock, AFR at 10.5, and my injector duty cycle maxed out (spike to) 61%.
Converted to e85, Precision 6266 Turbo, GN1 Aluminum Heads w/ roller rockers, 212/206 Roller Cam, Terry Houston 3" Downpipe, ATR Pitbull Exhaust, Racetronix 510 LPH double pumper, Power Logger, Wide Band, SD Turbo Tweak Chip, 160lb Injectors, Hemco modified 62MM upper Plenum, Precision Front Mount, Relocated Air Filter to under front air dam with 4" duct work ("Tylco Tinman system" ), Jimmy's Stage III transmission Vigilante 2800-3200 convertor
