Brer Rabbit
Pursuit Specialist
- Feb 5, 2005
E85 prices.
E-85 is 2.57 around Chicago.
SignUp Now!What a/f ratio where you running?
You can't compare E-85 to gasoline or even Race gas for that matter. You put E-85 in a car, use the same timing, boost, etc and change nothing but fueling and you make more power/ torque immediately. In fact E-85 is alot more forgiving than gas, so much so that you know have to worry about breaking the engine before knock occurs.
Going to bigger injectors and better fuel lines is a small price to pay to able to use the same setup and get at least 20% more power even more safely than you did before..all the while having a very clean burning engine. We all know how these cars dirty the oil quickly, anything to help that is an added plus.
No apologies to the race gas or alky guys but E-85 is the future of real power at an affordable price. Alky is affordable but the power you can make will be less period!! I know of plenty of people that have now taken their Race gas out or removed the alky injection system in lieu of E-85. Its hard to get in most places but once you run it you will see, its that simple.
TOM Did you buy chance notice how much your EGTs drooped from before without E-85??
Do u have proof to back that up. A local discussion around here is not in agreement with that and also about the cost factor. The fact that U have to burn more of the E-85 as compared to straight 93 Alky negates the assumed cost savings. For example it may take 1 gallon to drive from point A to point B using 93 octane at a cost of $3.40 a gallon. That same trip using E-85 will cost u $3.43 because ur consumption of fuel will be about 1.3 gallons. (Assuming ur getting E-85 at 2.50 a gallon, 1.3 gallons=$3.43) So yes U can run higher boost, but that will require even more fuel with E85 which again cuts into the assumed savings, maybe even putting U in the red compared to 93 and alky. Those are my numbers check em out and let me know if Im wrong.
just because one can run 25 psi and 25 deg timing , dont ASSume that the same amount of power is being made with the e-85. this same motor on 110 would make more power. im not trying to bash e-85. its a good alternative, but its not a breakthrough.
Im just trying to make sure my numbers were correct or close to itin my earlier post on this topic.
