I don't know who DLS is, I will do a search.
Here is a example of one of Dan's engines setting a record not even turned up yet.
YouTube - TSO Qualify #1
I am very happy with his work, he will not steer you wrong.
SignUp Now!I don't know who DLS is, I will do a search.
Chuck,
I believe DLS does not use the CAT crank in their stroker kit (seems they are getting real hard to get these days) so I would assume that you can still a stroker kit from them if you decide to go that way. It's always cheaper to build a strong bottom end once than to hurt a weaker one and have to rebuild it again a second time.
Remember to clean or change the tranny cooler if you re using one.
When you are done with your motor, will you be selling the torque plate??
if so I will need one for my machinist also, to use on my motor as well, let me know, thanks.
Ron
I believe I have read about people doing the machine work on their main bearing bores with the torque plates attached to load the block as if the heads were attached. Not sure if this is common practice or not, but it makes sense to me.
Finally got the motor home on 12-26, I had some time and looked over the situation today. The crank is in and torqued down, the girdle is on and "The Good Stuff" was used to seal the block/girdle split, the rear seal is in. The rings are on the pistons and where filed in to size, but not installed in the block. The block was line honed after the girdle was installed, and the cylinder bores where finish honed with the torque plate on. Then the rotating assemble was balanced. This is how I picked it up from the machine shop. $1656 for this work.
I noticed that the crank counter balance wieghts still have the casting marks on it and that the drilled holes in the counterbalances where not deburred. Also at the one corner of the girdle I don't see any "good stuff" oozing out from it. Even though it is torqued down and the rear seal is installed, I'm thinking of taking the crank back out and cleaning up the crank counter ballance casting. I already deburred the holes in the counterweights.....
I don't want to chance that girdle leaking so that has to come off, might as well clean up the crank while it back out right?
Chuck
