84BuickGNYorkPA
Daily Driving Buick V-6 Turbo's 1979 - Present
- Jul 5, 2005
Thanks Ken for the information.
Yea, the balance holes where deburred with real fine emory, not even a .03 chamfer, just took the sharp edge off. I'll let the crank alone at this point since it is already balanced.
I verified that the "right stuff" is in the questionable area, visually I can see it on the inside of the block/girdle in that corner area.
The girdle is already ground for clearance for the oil pick-up extension, (just did that before reading your reply). I would have ground into the mounting hole of the extension, if I would have groung the clearance in that(oil pick-up extension) instead of grinding the girdle. I tried to catch all the grinding dirt with oil soaked rags but some still got away. I called the machine shop and told them that I am pretty sure that I need to take the crank back out to clean it good, not to mention the block. I was surprised when they told me to use brake cleaner and air to clean up the mess.
I bought the extra capicity oil pan from Jason, but I'm having second thoughts on using it, I guess my main concern is the pan flaking and is there really a need for it....
I have the crank scaper, after the connecting rods are installed I will install the scraper and check for clearance with rotation of the crank.
Thanks again for your advice and guidance.
Chuck
Chuck
