87 Turbo Ltd. with 38k miles. Stock. (coil pack is even still marked 3/2/87)
Installed new IAC, plugs, radiator, standard actuator with rod set long, TT 91 street chip with stock injectors & Scanmaster. Numbers are good.
No other aftermarket parts that I can see.
Only slight hiccups are a few very small backfires sometimes on deacceleration, cranks a bit too long when starting (hot or cold) & it sounds like it has a more aggresive than stock cam. Might be the mufflers. They're the originals!
Barely driven since 1991.
Question - What to replace next? It will never be raced. It's grandpa's (that's me) car. A kind of go reasonably fast with cushy seats. Not concered with ETs.
Guessing fuel pump & filter? If so, do I need a bigger than stock pump & would it have to be hotwired?
Replace injectors with stockers?
Etc., etc.
Any and all suggestions would be appreciated. Also, in what order should I buy/install the new stuff?
I don't want to buy what I don't need, but I also don't want to need something that I didn't buy.
Etc., etc.
