Rafs-T-Type
Not so Senior Member
- Mar 8, 2009
Plenty of us have blown hg's and I read that it really messes up the bearings, but how many people replace the bearings? How do you know if you need to replace the bearings?
SignUp Now!If you have good oil pressure are you ok then?If anti-freeze ends up in the oil pan and sits in the bearings, they are shot. The anti-freeze eats the bearing material.
At a minimum most drop the pan to clean out the fiber that many head gaskets have in them. Otherwise it clogs the oil pump pickup and the bearings go away from starvation.
RemoveBeforeFlight
c n avoid87 said:So something like this, i had no antifrezee on oil. Just changed the gasket..u think i should of checked the bearings?
bison said:Change gaskets. Nothing else is needed. Find out detonation source
This isn't your new car is it?Coo.. Too much boost was the source ;-). Alky pump was leakying bad..
TurboBuRick said:Wasn't that a fel pro? Came out the front of #1?
pacecarta said:thats actually the bottom and its #4
and it looks liek it started to push toward the valley , did you loose any of the gasket graphite in that location ?.. if you did its in the pan and on the pickup screen
if you had antifreeze in the motor and didnt flush it out with water its also a good idea to drop the pan and make sure its clean and free of any antifreeze , just draining the oil from the drain plug wont get it done
I wanted to, but it would be a bad choice until I figure out this fuel issue. I think I would be all right, but it would suck to find out I wasn't.Yes fel pro 9941's i belive..n no #4? Lol.. Corrected. ...is all gud now. Tho. Hey jason i tho u wanted to go to the track?
Rafs-T-Type said:I wanted to, but it would be a bad choice until I figure out this fuel issue. I think I would be all right, but it would suck to find out I wasn't.
Rafs-T-Type said:Eh, if I lower the boost and don't see much correction with the powerlogger I should be ok. Just gotta make a couple 1/8 miles before going all out. Then again I might have the same answer next week. It probably isn't a good move to go to the track when there is something funny going on with the fuel system, but then again a couple runs there might help diagnose the problem
