- Jan 19, 2005
HR bar user here, and 100% happy, fit great and easy to install
SignUp Now!Does any body know where the best place to buy an H&R Bar?
Thanks,
We go from in-stock to out of stock VERY fast
My friend & employee Dave England (answers phone for me) used to live nearby & we got together often & were on the same page with inventory. Well, he moved close to Louisville, KY well over a year ago (time flies), and our sales have been going up (direct and to vendors), so I don't have the chance to keep Dave updated on inventory status like I need to.
We are usually not more than 2 weeks out on anything at any given time, and have been caught up on everything a couple times too! woooohoooo!!!! I told Dave it's SAFE to quote people 2 weeks on stuff (right now & lately), figuring getting it sooner than expected is better than saying 2 days & it's really 2 weeks (like other parts from other vendors, not necessarily Buick vendors either). If you MUST have it sooner, PLEASE order it sooner We don't bill it until it ships out, so you can order it a month ahead & even tell us the day YOU want it to ship.
But if that's not the case & you are in a hurry, just ask Dave to double check with me (Paul) and see how soon it can ship out cause it really matters (or email me first). I might have 1 here that is for another customer, but they are waiting on control arms or something, and could send that one & not effect the other customers actual ship date on the whole package. Or could have stuff done powdercoated or boxed up that day & Dave wouldn't know it right away. Not a perfect system for sure, but works as I grow & keeps me more "hands on" making the stuff to keep quality & craftsmanship WAY up there.
PS- In the picture above, our upper axle brackets are made to go OVER the brake line to make installation a LOT easier. It works either way, but designed to make it look better & go easier for you guys. You can also spread the brackets apart a little more too. Should be into the bends of the bar a little, approx 27" apart center to center. That will help even more on the handling!
As for actual differences, we have been into Buicks & supporting them for MANY years now & don't plan to ever stop. For those "thinking" of getting into it now, well that's nice & all & may be helpful, but I would hope supporting the events & the people all these years means something. Otherwise, I guess we have been spending our time/efforts/money in the wrong places! We posted over $4500 in prizes last years Nat's, and more at other Buick events. We also gladly crawl under a car at the event & help with tuning or installs, and take stuff right off our display or even prototypes to keep a guy racing that broke something.
Not to mention the "other brands" you keep seeing are attempts at copying my design. Myself, I wouldn't buy a copy at any price, just supports the reason new (and old) manufacturers lose interest in making anything new, cause someone will just copy it & make it cheaper. People don't care if it's easier to install or to tune or even stronger, just cut the price & hope to steal some of their business. It's one thing to make a better mousetrap, or have a major twist on the design, not just a cheaper version of it. Of course I should be flattered people like my design so much it's worth copying
I realize money is tight for many too, and you need the best bang for the buck. As with most stuff, you get what you pay for. There are MANY differences that are hard to see from ours to the other (copies) out there. Unfortunately, just about anything will work better than stock, making your decision harder. I know and can tell the detailed differences, and they add up! It's not that there may be something actually wrong with one of the others, just differences.
Along with our never-ending support & customer service, here are some other differences you can weigh out for yourself:
Our axle brackets, even though they LOOK smaller/weaker, they have many sharp gripper points on top brackets, and clearance for the brake line, and are laser cut to precise fitting size for specific axle tube sizes. (PS - TR's have a 2.63" dia tube, NOT a 2.75" dia like some describe) We fit those, the aftermarket 3" ones, and any 9" with 3" or 3-1/4" tubes, with back braces or without. Other brackets can't be used on 9" housings with back braces without welding and modifying.
The lower brackets also have gripper points, and welded end caps to really give them strength and support. Once tightened up, there isn't anything that can flex & reduce clamping pressure, and has more pressure per sq inch. Kinda like you don't see real wide tires on trucks that snow plow. They use skinny ones that dig in & have more weight per contact area.
We also use a heavy duty poly bushing, unlike some others use the thinner wall "cheaper" ones. Not only will ours last longer, they reduce any binding under load and allow for MUCH more side loading for added handling ability. That's why we get so much great response from street guys & gals out there. Even have some auto-crossing guys doing well with it. I personally wouldn't drive one without our bar, once I felt the before & after.
Our upper crossmember brackets are a fabricated design from 1/4" steel. Others use 1/8" angles that are not even connected & nowhere near as strong even when bolted up. We also include an upper plate that reinforces the crossmember so it doesn't flex that others leave out.
Some use a female & male rod end, so you MUST take them off to adjust them. This is a huge hassle, especially when you consider how hard they are to get to when on the ground & the fact that they should be always set last after any suspension changes are made. Just another way to cut costs in production, but makes it harder to deal with after install.
And probably not the last difference, and probably the most important difference, is what we make the bar out of & how we make it. Ours is from a 4130 Chromoly TUBE with 1/4" wall, not a much cheaper solid bar. After we bend ours, we HEAT TREAT it to make it act more like a spring & return 100% to it's original shape every time. This also makes it stronger because it heat treats the inner AND outer surface. Like the PRO axles out there that get gun-drilled & heat treated, a LOT stronger & lighter too.
Our bar, with all the brackets, rod ends, grade 8 hardware, packing materials etc, is lighter than the "BIG" ATR style bar that bolts to the control arms. At a little over 4' length of material per bar, our thick wall tubing with powdercoat would be approx 11 lbs. The same length in 1-3/8 solid would be approx 21 lbs! And even though it "sounds" stronger being bigger dia & solid, it's actually weaker and will not come back to it's original position as good.
We also include the necessary drill bit (and a smaller pre-drill now too) and a yellow crayon to mark holes now too. Will soon have easier layout for holes too. Always thinking of how to make it better & easier FOR YOU, not what's more profitable for me. I am a racer and perfectionist at heart, so I try to offer what I would like to receive as a racer/customer. Plus with our very detailed instructions with tuning tips etc, extra attention to details & craftsmanship & even packaging, I guess I could see where someone would say "no comparison"
PS- We intend to repeat last years efforts to pay out contingency awards to anyone running our swaybar and/or suspension kits. It works out very easy! Just stop by our booth, ask for a HR license plate or decal (if don't have one yet) and display it while racing & time trials etc. If we can get a picture (from you or track photographer or??) that shows a good launch & a time slip or proof of a win or RU at the Nat's (and maybe other events too) to use on the website and/or catalog, we hand out the prizes! Got some great ones from last year, and our fault for not getting them up on the site yet, but that's another issue we are working on. Got a new site, new parts, and lots of info/teck/etc coming soon. We make sure everything is 100% before we go to production, so we are now keeping stuff more "secret" until it comes out so others don't copy that stuff too. Going to be a VERY interesting year for us! Getting help from brothers at our machine shop too, so new projects are coming along faster now too. I get so excited I can't sleep at night! Now if my back & neck can just keep up with my mind Gettin old sucks! Unless you are rich & don't work & can sit in the spa all day & have food & drinks delivered to you..... One day maybe if I keep working those 14-16 hr days 7x a week :frown:
Paul i ran the brake line like that, cause there wasnt room for it, because of my old TRZ style weld in sway bar tabs where in the way.. But hands down this is the best sway /anti roll bar i've ever used, thanks for a bad ass product..
PS also using your engine and trans mount
Paul--
Any chance you'll have a redesign on the bar so it doesn't hang down quite so low? I don't mind the price as much as the look....
Thx!!
thanks for that input - money is scarce these days and dont wanna waste 400 bux... can you elaborate on the major problems with the BMR?
well after seeing the H&Rbar in person & riding in my brothers car.............
i got mine 3 weeks ago sitting on the back room floor uninstalled so far!!!!!!! (thanks Paul)
PAUL,,,what about HR putting out a small front sway bar for street strip cars running your rear sway bar and upper and lower arms ,,just to complement the rear system,,,most of our cars are mainly street cars with some strip use or one that can be quickly ditached for the strip,,,,,,,,,,LOVE YOUR PRODUDUCTS
