conn84gn
- Jul 13, 2005
I'll check them out
piratejack.net
Ok parts are here
I read that with the PSC reservoir I don't have to use the Tee I had before.
Just a note this is a 84 GN with hydroboost with a 87 motor setup.
I'm thinking I won't replace the high pressure lines just hook them up
Also rebuilt pump from Cardone has a small O ring stapled to the inside of the box cover that they say needs to be replaced where does it go?
I plan on sending the old pump for a rebuild to Turn one
I bought the hose and fitting kit didn't want to mess around chasing fitting
Old pump removed and new one in place you will need a pulley puller to remove the pulley
I used Lisle 39000 $46.00 from Home Depot free next day shipping could rent one too.
Looks like I will have to make a bracket for the PSC reservoir
I'll be posting pictures over the next couple days
Hose Kits for PSC Remote Reservoir Installation (Hydroboost)
High-quality PSC Power Steering Products are a must for any high-performance project! Use this hose kit to connect a PSC Remote Reservoir to a PSC Power Steering Pump on applications WITH Hydroboost brakes. For applications without hydroboost brakes, click here. Don't see what you need or need...www.pscmotorsports.com
Is the link to the kit with photos. I'll take a look at it and snag some photos.
So no specialty connectors are necessary on the "far" end of the reservoir lines. The high pressure fittings I used came with my Hydratech kit so I can't speak to those as well.
Thanks @Cryptic, that helps a lot! These are all low pressure fittings so I knew the fancy connections probably weren't needed but I was sure if all the lines would actually fit on the appropriate connections and this answers that.
