If you seriously want to run E85 in the tens you are going to need a serious fuel system to support it.
You'll need to drill out the four Saginaw fittings on the fuel supply line and install Red's double XP set-up. DONE.
SignUp Now!If you seriously want to run E85 in the tens you are going to need a serious fuel system to support it.
A Hotwire is a must,too.
The stock 1/4" return line is marginal in normal use
First, you cannot have too much fuel flowing if the regulator is doing it's job, and the system is set up properly
With the "personal" BS behind us.
I am somewhat confused about the "issue" of heating the fuel being returned to the tank? In all my years of doing turbo car, this is the first time I have heard it being an issue?
With my understanding of an AC system, vapor is compressed
What am I missing here?
If you do not like a DW pump, I could care less, I do not have to defend its performance to you, as my customer's trust me and what I sell or recommend.
My Walbro mght be out. Which pump to get now? I want to stay with a single pump. I am getting a RJC F/M. My goals are 10.5 in the 1/4. I have a TE-66 big shaft turbo. I might get Alchy soon and E-85 conversion sometime later. Please chime in. I know of the Supra, Stealth, Bosch 044, and Deutche? pumps.
To heat the fuel,even,more?
And when one pump fails your motor is DONE.
I'd like to see some tests and actual numbers on this *fuel heating* issue in another thread.
Just how much heat dissipates from this *heated fuel* while it is away from engine heat?
Is it worse to have the fuel pumped to the engine,then sit there without being returned?
Maybe it's time to find that Cool Can I've got stashed away somewhere?
Sounds like this is a good reason to not use one pump.
Here are the only two questions,that a person who was looking at the DW pump, should ask.
Is there a possibility that I'll have to modify my return line if I buy this pump.
Will this pump heat my fuel up more than a lower volume pump.
These are the only two possible down sides to this pump and should be mentioned in the sales pitch.
Again,I'm writing this because the OP wants as much information as possible so he can make the best choice possible for his situation.
If anyone doesn't mind modifying or replacing the return line,he might want to buy this pump.
There are people in the world who might not like the idea of a system that heats the fuel more.
If you like the Idea of warmer fuel,buy the pump.
Can someone,please answer these two questions correctly.There's only one correct answer to these questions and everyone knows what they are.
Each question can be answered with a yes or no.
If i run one pump and it fails the car wont run.
you have one pump fail to turn on at high boost and your motor is DONE.
I shouldn't even waste my time with this,
Is there a possibility that I'll have to modify my return line if I buy this pump. Yes, there is a possibility. And if he is one of the very few that does have to modify his return its a simple process.
Will this pump heat my fuel up more than a lower volume pump. Yes, but will the lower volume pump supply enough fuel for the application given?
Also will 2 walbro's heat the fuel more then 1 DW pump? Thats a yes or no question as well.
DP so its the same BS
Do you know anyone or have you heard of anyone who,while in the middle of a quarter mile pass,has had there single pump turn off like a light switch. No. What happens,in reality,is that the pump gets less efficient and the WOT fuel pressure starts to fall over time. If you monitor well,you catch it. If you don't it can bite you.
There are many things that can go wrong when you push a motor to its limits. That's not what we're talking about.
How many people has this happened to? The pump that fails the most,in the turbo Buick world,is the alky motor. Do you recommend that no one use alky injection because this might happen? No. Again,this isn't the issue. Even if these second pumps where dropping dead left and right,does it negate the fact that the DW pump can require a fuel return modification. No. Remember,this is what is at question here. we're just giving all the pros and cons of the DW so the OP can make an informed choice.
It might be simple for you,but not for some. Some people don't want to modify there lines. That's why they need to be aware that it might be necessary. Again,we're just making them aware.
Yes simple for me. How many people have had this issue? i would say there is a 95% chance they will be fine. if they do have a return issue its a easy fix that we can guide them and get it fixed. Your making it sound like where butchering the cars fuel lines to make them flow if they have a return issue.
People who own Buicks from stock to heavily modified will be considering the purchase of this pump. The Walbro will satisfy the needs of the stock to 500hp level. It won't heat up the fuel as much and it won't require the modification or replacement of the stock return line. Again,these are the only concerns that some might have a problem with. The OP for instance. So he needs to be told about these issues so he can make the choice. If the lower volume single pump isn't enough for the application,we can add a second pump and there will still be no need to modify the return line,nor will there be a heat issue.
I'm still waiting on you to provide data on this fuel heating issue and how its going to effect the car.
This statement speaks for itself. Some people might not like this fact and should be told about it.
No. The majority of people ,in the turbo Buick community,drive there cars on the street. This is when the fuel is getting returned to the tank in large quantities and getting heated. If you run a double pumper set-up,the second pump is never on while cruising. You're only moving a volume of fuel that the primary pump is producing. If you have a larger primary or a single DW,more fuel gets heated and returned to the tank.
This is why people need to be aware of this.Once they're aware,they can make there own choice.
Again, Please provide data of this fuel heating issue on the walbro vs DW. They heat difference will be nill if anything.
Please,feel free to quote a statement of mine that isn't true so others can see it.
