SignUp Now!Cmon earl, you mean the volume level right? Its too fast and mostly goes away when driving. Ive changed the oil filter twice so far, ill get them cut open. Ughh..Good god, that almost sounds like rod knock.
No. Seller thinks comps but not sure which ones. Full throttle thinks morels.Did you ever figure out what lifters you have?
I would replace them and be done with it.
Just thought, its also 50 degrees cooler here now.... On average, what percentage of fuel are you adding?unrelated
Rule of thumb:Just thought, its also 50 degrees cooler here now.... On average, what percentage of fuel are you adding?
Almost spot on, thanksRule of thumb:
+2.5% for every 10F drop from baseline temp tune
How about the lateral play in shis spacer?
The noise is driving me. None of the lifters were soft at all when I reset the preload.
Do you mean adding 2.5% to the entire A/F table or are you referring to the VE table? Im thinking you mean the VE table since the air will be colder and more dense and therefore requires more fuel to attain the target AFRule of thumb:
That's in % of fuel.Do you mean adding 2.5% to the entire A/F table or are you referring to the VE table?
Uh, i dont. Im getting kr before wot, when i didnt before. Do you bump up fuel at the regulator too?Gotcha. Thanks Jerryl
