jasjamz
THS Racer
- Sep 30, 2004
Much appreciation to you guys for your time and effort. Really good to see this going on.
SignUp Now! ...Bison and Otto come with proof that bigger is NOT always better.
...Bison and Otto come with proof that bigger is NOT always better.  Thanks for sharing!
Thanks for sharing!With tall 29" tires and 30psi and converter locked it will run tens. More turbo would help you a lot
Brian I have a 66 with 85 housing here if you need to try that too with my big Turd turbo .
Thanks bison. I built it to handle more turbo in case I want to go bigger, but really don't care to hit 10's at this point. I'm building this primarily as a street car that can pull mid 11's on pump gas and alky. I'm hoping my little 44 will come on fast and hard with this combo.
I'm glad you guys are doing this testing as I'm still trying to figure out what turbo I will eventually want to upgrade to.
We will see how going from a ta49 to a ta6265 with heads and cam hopefully next week.
Now since I am on a cruise ship Im gonna go grab drink and enjoy a few days off
have fun...thanks for the info guys.subscribed. interested what the limit of my ta49 is....
85* at the dyno and 74* inlet temp at the lowest for the 61 turbo and 79* at the lowest for the GTK. About 1% loss or gain for every 10* gain or loss in inlet air temp. The sensor is mounted in the plenum area. hSince you guys stay UP north where it's a tad cooler and some of us DOWN south where it's hot. Would you mind if it's not to much to ask recording or telling the outside air temp? or the Air temp entering the turbo on the dyno? {IAT}
(I know Bison said "with good air") but just a base line figure or rough estimate of temperature your running these turbo's, please. Or would it not really matter?
You know like:
the outside air is ___*(be it in the shop or outside)
the air temp in front of the radiator or entering the car is ___*
then the rest of your results....
If it's too much don't worry about it and carry on as usual, I'm still watching and reading, regardless..
Just wanting to get an idea like, if its such and such degrees I may get good traction but no since in making any more runs beating on the car since the weather is too hot. Save it for better air day.
for example, like Bison gave in his 1st post.
I know all variables will NOT be the same. But say like this certain turbo is running pretty good in the ranges of 80*-90* outside Air temp or Inlet air temp. If it's higher than that-- too hot-- and will probably run worse. If the temps are less than the 80* you MAY run better and can inch up the boost.:redface:
Or am I thinking too much into it.
