greeneyegi
- Feb 21, 2010
ive had this problem every once in a while.
it only happens when i start the car,never after its been started and running.it doesnt matter if its cold or hot.finally i caught it and i got a log.
i will start the car and it runs like its completely flooded,smokes,and sounds like its running on 3 cylinders.some times i can restart and it goes away.sometimes like this morning it wouldnt go away.i started cold this morning and it happened.i restarted a couple times and its still doing it.so i got out the laptop and got a log.its got a code 34 of a mass air flow reading low
and 24 vss signal reading low.
i took the iac off and it still idled and ran on the second log.
the third is a good running car the last time it ran.....any ideas will help thanks guys
pxl wideband
pxl wideband
