Welcome to the WindowTurbo!!! This is a prototype that ALL BUICK lovers have been waiting for. Requires removal of the window circuit breaker and 2 wire install, then a ground wire... THATS IT!!!! It will take longer to remove the lower panel than to complete the install. There is no removing the door panel, no cutting and splicing wires or anything. The module is just a slight bit larger than a scan master. This is work from Richard Clark and Howie Hoyt.. All first runs are sold out and we expect the next run mid February.. As you can see from the other video in this particular case it cut the window up time IN HALF!!!! The module will retail for $140 and only 1 per car is required. Does not matter if the car is running or not, in this example the car just had the ignition key on and motor not running..What does everyone think??
BEFORE:
AFTER:
BEFORE:
