SignUp Now!I'm thinking one of the pumps got weak, and cyl 1 is the last piggie on the tit so it burns up first. I know, I know what you are thinking (double pumper?!) But the hanger has two separate -6 lines Y'd into an Aeromotive filter, -10 to the rail (Saginaw fitting cut off and -10 fitting welded on) and an Accufab reg with the bottom cut off and hole opened up with a -6 return welded on. Fuel pressure was right on on the dyno. And this same fuel system was on my car (different car) and fueled it to 9.60's with good fuel pressure and VE table numbers that jived.
This time I'm putting a proper pump on it, double feeding the rail, and logging FP. But if it's FP dropping all of the sudden then I'll be right back where I'm at. So.... new fuel system it is.
John, have you flow tested the fuel system on the car? (crank the reg to 67psi or whatever it is at wot and run both pumps to measure how many lbs of fuel it flows) I never did this to mine yet but then again I'm not having the same problem. I believe you flow it for 1 minute, weigh the fuel, multiply by 60 for lbs/hr, then multiply by 2 because the bsfc? # is around .5. That number should tell you how much flywheel hp you can support.
John Plog
I havent flowed the pumps but you can bet I will.
It was 3 gallons 112 and 5 gallons 93 and meth with 2 M10 nozzles.
x2 race gas is a life saverI put my car on a strict diet of strait Sunoco 116 just to prevent a scenario like this. I don't trust any pump gas or alky at these levels of performance... just one little blip of trouble and you have melted parts on your hands.
