LVD 6/6/2014 10.236@132.27mph
You have transbrake ,, because a friénd tell me to remove for best 60 foot
I have a stock suspension. The car just squats anyway. It will squat more with it off.
Brian,
How much timing?
The timing is variable from 5000-5600. Lowest at flash stall and some comes back as it recovers. I think it was 17.5* actual at flash and 19* at 5500? Might have been 18.5* at 5500. This timing info doesn't mean crap on another car even with the same exact parts unless timing was verified. The tdc position was verified on assembly and the timing was verified on this engine after if was started. Without doing that comparing to another car that didn't verify is a waste of time
Mmmm interesting. I just ran my car, chip timing was set at 19° however after second car wouldn't start. Discovered cam sensor moved 60° CW. Still ran 123.xx bucking down the track. :wtf:
If you want to get more out of it and want to keep the simple 5.7 chip you can have the timing vary by mph. You will be able to get more out of it. I can say if I ran 19* on my engine with the boost and heads I had it would be on the edge by the 1100' mark.
Follow up dyno with same tune as run at LVD. 93-94 degrees and 38.4% relative humidity SAE:
Over 570whp from 5100 to 5500
BPE2013@hotmail.com
