If I do blow the tires off, it seams to do it on the 1/2 shift. With the 3.73 gear out back for streetability, the 1/2 shift comes on real quick. Last time out the car did a 1.50 short time on a 5 lbs launch.
Car has 1" lower (and stiffer) springs at all four corners with Bilstein shocks. Rear has HR boxed LCAs, and Metco adj uppers. Air bags have 8 psi left, and 12 psi on the right. 275/60/15 MT DRs run aprox 20 psi.
For track duty, I throw on the 90/10 drag shock on the front and loose the sway bar. And that's about it.
I'm sure that a looser spring up front would transfer the weight better, but I don't want to give up the way it handles on the street to do that. Can't seem to remember what I set the pinion angle at.
So, does the converter slippage in the upper RPMs look like it's not too bad?
Thanks Mike B.
