guys
they only way alot of people are going to fill it-
is if they return there cars to real stock looking higher dollar status vehicles;
meaning whats under lined in the rules of the bone stock class
JayC said:Stock TTY bolts - Who is going to put heads on an engine and use stock bolts? No studs I can see (Which even that I think is stupid but whatever) but stock TTY bolts? No logos on the heads? So ported heads are allowed as long as you dont use Champions or anyone else that stamps their logo on the end of the heads?
There probaly isn't enough TR owners that remembers how a stock air box installs..that is pervided they find one![]()
Ok, to be serious, I'm guessing these motors came stock with TTY bolts? I'm also guessing we're talking about Torque to Yeild bolts? If so, TTY bolts are none reuseable. You simple chunk them in the trash when you pull them out of the head. So I'm with Jay on this one as well. I would be very surprised to hear of anyone reusing TTY bolts. It wouldn't surprise me if you had to buy a TTY bolt from some aftermarket company like Fram. I had to do this once because Ford had stopped making bolts for a car. Anyhow, I think pulling a valve cover to inspect for stuff like studs or stock TTY bolts is over kill.
"Ok, to be serious, I'm guessing these motors came stock with TTY bolts? I'm also guessing we're talking about Torque to Yeild bolts? If so, TTY bolts are none reuseable. You simple chunk them in the trash when you pull them out of the head. So I'm with Jay on this one as well. I would be very surprised to hear of anyone reusing TTY bolts. It wouldn't surprise me if you had to buy a TTY bolt from some aftermarket company like Fram. I had to do this once because Ford had stopped making bolts for a car. Anyhow, I think pulling a valve cover to inspect for stuff like studs or stock TTY bolts is over kill."
"This class is a very cool idea but they reeaallllyy need to relax on the rules in order to have enough people to fill it."
yes but how many people have something like that....not a whole lot of people...i think with a certain set amount of money not alot but a little money you would have some great racing a huge turnout and you would get all sorts of diffrent "recipes" to get a car to go fast and cheap...sure you can still do your totally stock looking bored/stroked engine but i think if someone is making a new class, why not try to get the best turnout and response possible?
You can also still get a correct looking TTY bolt.
Jugular said:How much more relaxed can you get.
Jugular said:It's all in interpretation. Rules are bent in every class.
Checking for bolt castings isn't relaxed in my opinion.
well comparing these rules to say TSS I would say they leave alot to the imagination.......
Scott231 Umm, Turbo Street Stock allows Stage motors. How is that anywhere near "stock"?
well then maybe someone will take a unoriginal not quite ruined one and return it to a higher value dollar car to race.This class imo is a waste of time for the simple fact that no one is going to want to alter their low mileage original GN to compete effectively in this class.
tty is correct-and available- no exceptionStock TTY head bolts? Thats ridiculous. What if the heads had the correct stamping on them and they were some other bolt? Is this still legal?
now your getting the idea-No mention of turbos as long as they are stock appearing. This is a low 11 sec class when you spend the thousands of dollars to build an externally stock appearing super stocker engine.
if you and jay are bad enough -do it- its not nascar hereI second JayC's response to the hidden nitrous. I could do it and i know it would not be visible.
no grey areas at all if you read the rules-they were already addressed twice now.Too many grey areas here that need to be addressed.
NO POWER ADDERS UNLESS THEY ARE TOTALLY INVISIBLE TO TEC JUDGES---IF WE SPOT IT---- ITS OUT!!!
No body braces?? I was almost tempted to make a few changes to run this class untill i saw that. How can these be a performance advantage or disadvantage? I just like to keep my pillars intact. Who is going to launch there stocker on drag radials without them? I value my car to much for that kind of sillyness.
Sgrim said:Bottom line is the rules are strictly up to the official at the time of the race right?
GNocide said:original downpipe with original type wastegate and solenoid----wastegate may be modified to make it adjustable
along time ago cars where doing low 12s almost bone stock.some vendors advertised it was less than $1000
WITH NO BRACING OR SUSPENSION MODS-
CAN YOU IMAGINE THAT?
it really happened-
you may not have been around then
its amazing that anyone arguing over this has ever had there car out of the 13s
#the only confusion is people posting without understanding or fully reading
wrong-they are posted here along with a large paragraph of explaination posted after the fact on page 2 or 3 in reference to jays comments
WrongThat post you put up didn't clearly explain anything. If anything it made it more confusing.
#exhaust doesnt have to be stock BUT IT HAS LIMITS-reread it
# the rules dont say you have to run any amount boost or even have a wheel in the turbo-just a stock looking turbo under the factory shield hooked up to factory plummed intake system.
