TSA Class GSCA Bowling Green 2009
Dennis Kirban
Turbo Stock Appearing Class is sponsored 100% by ZDDPlus™. Last year was the very first year for ZDDPlus™ involvement.
This year the purse has been vastly increased. Call it the ZDDPlus Stimulas Package since the word Stimulas is now the new catch word.
Here are the purses:
Finish first and it pays $3,200
Take second place walk away with $1,600
Third place you take $1,000
The company has added fourth place this year and that pays $500
It gets better. If you win any of the above 4 slots and obtain a silver or above win in the show car portion of the event the purse doubles! This means potentially if you won top place at $3,200 and you finish above silver in the show you walk away with $6,400. That's a lot of dinners with the wife.
Also, every year after this year the amount of prize money in each class doubles until someone breaks into the 10 second bracket. When this happens Richard Clark wants to buy that car! Check out the GSCA website for the rules.
A word of advice you will want to have ZDDPlus in your oil. We will have it available for sale. We will also have ZDDPlus™ windshield decals available at the event.
ZDDPlus™ is also one of the 2 major sponsors for this years F.A.S.T events along with Nationals Parts Depot. This is another nationally recognized event that features stock appearing muscle cars.
This is totally sponsored by ZDDPlus™
All the above figures are correct.
kirbanperformance.com
denniskirban@yahoo.com
Our company is the largest seller of ZDDPlus in the country. The company behind the product owns the largest Turbo Buick collection in cars & parts.
On a side note we now have as our spokesperson the biggest name in drag racing for 50 years - Don Garlits. His list of accomplishments is impressive to say the least.
Brett, I guess that puts me up to 8 cents worth rite?
Keep in mind that amount doubles every year until someone breaks into the 10 second range. In other words next year lst place in the 1/4 mile pays $6,400. If that same person scores high at the car show portion the payout is even better.
owned a few Turbo Regals over the years
Yea ur getten up there in cents....;) Your posts Dennis have been educational and more importantly good reading. Keep em coming.
So how exactly are they going to confirm that someone is using the additive? Will they verify by checking ones oil?
I copied this from the GSCA site. Makes it easier to find the rules...
TSA "Turbo stock appearing" TR class qualifying ET 13.2
The TSA TR class is intended to provide a race class for cars that are STOCK APPEARING. Unlike the TSS class where some visible mods are allowed for performance reasons, virtually all of those will not be allowed in this class. It is intended that with the STOCK APPEARING requirement, innovation will develop methods that will push the performance of STOCK APPEARING cars to a level that has not been achieved in the past. In some cases such as exhaust systems where original replacements are no longer available and haven't been for quite some time we will allow "reasonable upgrades". For the sake of these rules the term "stock appearing" does NOT mean similar to, better than, improved, really close, almost identical, should have been like this, what GM really intended, more stock than stock, they made a mistake and this is how my car was shipped, etc. Since the spirit of the class is for STOCK APPEARING cars we really shouldn't have to spell things out in much detail. This means if we can SEE it and it's not how the car was delivered its not allowed. Or put another way if you have to ask if its ok------ its not! [1]
No tools will be used for inspection beyond a light, mirror, ruler, scales and scan tool. No removal of parts or disassembly will be done in tech that requires tools. Cars are subject to re-tech at any time before or after runs. Car must have option sticker on trunk lid with VIN that matches car.
The qualifying ET is based on the factory posted times for a GNX. With poor tires, exhaust, chip and turbo (all allowed in this class) the GNX was able to achieve 13.2 as far back as 1987.
Suspension :
Must retain all original equipment.
NO frame mods or reinforcements.
Stock wheelbase, stock unmodified control arms front and rear with black bushings in original locations.
Since all the cars didn't come with the same body bushing compliment you can have them in all locations as long as they are GM bushings.
No frame braces that didn't come on the car.
No traction bars unless the car is an original GNX and then they must be original.
Rear seat braces are ok as long as they are installed and visible only from the trunk.
8.5 inch 10 bolt GM rear with stock stamped cover unless it is an original GNX. Posi may be added to non posi cars.
Must have stock dimension and diameter sway bars front and rear with black bushings.
Stock appearing brakes, drums back (alum ok), disc front.
Any type stock appearing shocks in stock location----any color ok.
Springs must be single coil design like original stock springs.
No air bags.
Car must sit at one inch of stock ride height. This would be 8" from road surface to frame rail measured at all 4 jacking mounts.
Engine compartment
109 block with no EXTERNAL mods.
All original equipment and sensors intact-no deletions or additions that aren't supported by build tag on inside trunk lid. Original size battery in stock location with original type side terminals and battery cables.
Original type stock appearing water pump.
Original, stock, externally appearing manifold, throttle body (alum or silver in color).
Original appearing starter and 120A CS alternator with stock appearing fan.
Stock accessory bracket with original appearing power steering pump/pulley and AC compressor/pulley
Stock appearing black coil pack.
Grey or black spark plug wires original size/length/diameter routed in original location.
Original GM headers with heat shields intact---may be welded for repair purposes.
Original diameter one piece downpipe (2.5"max)
Original type wastegate---- may be modified to make it adjustable (ie threaded rod).
Original type solenoid (one only) must be only control for wastegate.
Stock appearing 3 bolt turbo must fit under unmodified shield mounted in stock location with stock bracket with stock GM cast inlet bell with vent intact----the vent can be blocked but like everything else it must not appear from the outside to be modified.
Stock appearing MAF (AC molded with down turned plug)
OEM inlet flex hose with no modifications (tape etc)
Stock intercooler with no external mods with stock inlets/outlets mounted with stock brackets in stock location with stock scoop (screen may be removed)
Any size injectors in 6 stock locations.
Stock appearing fuel rail
GM 8445 heads with NO external mods or logos---- installed with GM TTY bolts. Any head gaskets.
Stock appearing unmodified valve covers (must be alum or silver in appearance) installed with 1 oem style cork gasket, NO spacers. Original filler cap and tube on driver side.
Original breather and tubing on pass side.
Stock radiator tanks. Additional cores can be added but support cannot be modified.
Original underhood wiring and loom must be intact with no additions/deletions that aren't supported by option tag-----only exceptions 1-alarm, 2- single relay and wiring for fuel pump "hotwire" upgrade.
AC may be converted to R-134 and must be operational enough to blow colder than ambient.
Powermaster with stock reservoir.
Stock unmodified air box (no holes when installed on car) with snorkel.
NO chrome if GM didn't do it.
Hoses must be black and clamps must be original color.
No engine tiedowns.
Aftermarket engine/tranny mounts ok if they use original mounting holes and black cushions.
Stock unmodified fans in both locations-radiator and crank. Original diameter pulleys and serpentine belt.
Tranny
2004R with no visible external mods except for 2ond servo.
Stock pan and driveshaft---loop ok, any convertor or transbrake as long as it is not visible under or inside the car.
Trans cooler ok as long as it is mounted and plumbed "GNX" style
Tires/wheels
Any matching set of 15" or 16" steel or alum wheels-------must retain original bolt pattern-------front tires must be at least 215 wide ------rear tires must be 275 or less DOT radials-----NO SLICKS
Interior
Full stock appearing interior matching option codes on trunk lid. Original gauge cluster, only addition to gauges is boost (2 1/8 max dia) and it must be pillar, column or console mounted.
Stock shifter
Radio may be upgraded but must fit in stock location with no visible components/parts elsewhere.
All windows must be glass and all door windows must function as normal.
Exterior
Complete car exterior retaining original appearance as it was on the showroom floor.
All bumpers (must be original steel), fillers, panels and lights must be in place.
All body panels must be painted--- no bare metal or primer.
No signs on painted exterior of car. Any signs on windows must be smaller than 1" letters, logos <2" unless they are from state inspection or a factory window sticker.
No fiberglass or ABS body parts except for bumper fillers.
Full size OEM aluminum or steel bumper reinforcements, use of aluminum bumper reinforcements does not have to match VIN tag in trunk.
Bumper shocks must be original steel/unmodified.
No mods to sheet metal, fenders etc.
Repro header panels and trunk spoilers are allowed if they are fitted correctly and look original.
Car may be undercoated.
Fuel system
Factory stock appearing tank, no VISIBLE additions to tank or pumps except for relay and wire upgrade
Replacement lines may be used as long as they are original size and are routed in stock location
233 or 237 regulator with no external mods.
Stock ECM with any chip, no other computers allowed.
Only one O2 and it must be installed in the original location.
Must run gasoline for fuel, no more than 10% oxygenators------any octane ok
No fuel additives, NOS, alcohol or other chemicals allowed
Exhaust
Downpipe must be one piece and attach to stock elbow in stock fashion (ie with donut and spring loaded bolts, downpipe must route in stock location, no flexpipe.
Stock diameter one piece crossover pipe (does not have to neck down on either end)
Stock appearing full length cat must be in stock location-- must be able to pass a 50 state VISUAL inspection
Original design or dual mufflers but must function (muffle) and exit in stock location, must be 2.5 inch or less pipes past "Y" connection at cat. No cutouts.
Minimum weight 3,500 w/driver lbs-------spare tire and jack does not have to be in place when racing or weighing
Purse will be $2900 if there are at least 3 qualifying cars. 1600 first, 800 second and 500 third. As an indicator of the spirit of the class, purse will be doubled for any car if it scores at least ________ [2] in the concours class of the car show. Car must race identical as it appears in the concours with NO changes except for wheels and tires.
Example: car places third in race class and silver in concours, purse of $500 would be doubled to $1000
Richard Clark will be the Race Rules Administrator. Any questions about rules clarification and or interpretation can be addressed to this board or to richardclark@ami-media.com
kirbans 2 cents worth
In answer to some of the above questions and comments. First thanks to Shane for posting all the important info to qualify for this class. I wll let my readers know where this info is posted as well later this week.
As a turbo owner, we are very fortunate to have a individual who not only has a tremendous long time passion for these cars, but has injected a lot of time and money through ZDDPlus to give some great cash prizes in what has to be some of the worst economic times most of us have ever witnessed.
If you have ever attended the GS Nats you know Richard Clark is always willing to help with anyones Turbo problems (mostly brake related) either for the shear enjoyment or the fact he loves a challenge.
ZDDPlus product the sponsor for this class is a needed product for all Turbo Regals even roller set ups. We now have proof of that from engine builders that build 1,000 hp engines and have torn them down and seen a reduction in cam wear etc.
As for the comment about having ZDDPlus in your oil, no we are not testing for that, however, you would be smart to have that in your oil if you are using regular current off the shelf SM oil no matter what brand it is.
I think to place in both the show portion and the race portion under this class you have to be in the concours class of the show which I believe is the stock class. In years past there has only been a few in this class. Granted it is a challenge, and I tip my hat to whoever takes the top monies or simply places in both categories.
One side note, although I am not a racer, if you are planning to qualify in this class a word of advice. Number one, it will be very tough to pull anything over Richards eyes that is visibly incorrect. Number two one of the simplest performance gains is shed as much weight as possible from the car that is not visible. At the very least aluminum front and rear bumper braces which as stated does not have to be listed on the trunk ID label.
Also note the prize monies I have listed is correct for 2009. What appears in Shanes copy above about the rules etc was I believe last years payouts. I have confirmed my figures with Richard.
Hopefully, it will be a cool temperature wise race day this year. As for the statement who has a stock appearing Turbo Regal? There are a lot of them out there based on our own customer base.
With these prize monies posted, it should be easier to convince the spouse to go to GS Nats this year, if your game plan is to participate in the TSA class.
Owned a few over the years some of which even escaped GM with decent paint.
Can't be any lighter?
BTW, from what I read in the above post and the rules, the car will need to compete in the Concours class. The judging sheet is supposedly 35 pages long. Can anyone post/provide/link a copy? It is NOT available at the GS website...
The car only has to be in the show if you want a chance at double'n up on the money.
K.
