Craig Smith
That was easy!
- May 25, 2001
AMEN brother
Well now don't try and make it sound like I don't like the FAST system. Both are very good systems and each one has its strengths.
SignUp Now!AMEN brother
Would not do that to ya Craig. I know your position very well as we have spoke about it in length when you were on the A team :smile: . Just supporting your stated fact that there are things the Gen7 will do that the XFI cannot. I have no issues with the XFI.Well now don't try and make it sound like I don't like the FAST system. Both are very good systems and each one has its strengths.
Does the Gen7 have auxilary inputs to watch other sensors?
IE.. driveshaft,c02,nitrous pressure,etc...
Need to do a little learning on your own. The dead spot is more than likely a lean spot. Jack will get you hooked up.
I'm buying a carburetor.
Can the XFI turn on and off any outputs using boost psi, TPS, rpm using only one or all of the functions?
Can the XFI activate several fuel and timing maps based on 12 volt inputs or time based on boost, tps, rpm, map%?
Does the XFI have any 12 volt inputs?
Can the XFI fine tune fueling using 1200 steps?
Can the XFI datalog several data logs before retrieving them?
Will the XFI allow user input bat correction voltage table?
Will the XFI allow the use of any aftermarket wideband meters
Can the XFI use dual WBO2 sensors
Otto we can play this game all day long. The Gen7 is short on additional inputs compared to the FAST. The fast short on outputs and has crappy one directional outputs. We can hash it out on a gen7 v/s XFI thread if you like. I have nothing to lose as a guy like yourself has no clue about what a gen7 can or can not do. Peace Im out
Was this really neccesary?
I am learning on my own and am progressing along very nicely thank you. As for the dead spot, WRONG!.
What the hell is the deal with the attitude of the vendors on this board?
" SCREW YOU if you didnt buy it from me" I posted this thread for some HELP originally knowing that Jack was driving back from the weekend of racing, what I get as a first reply is a smarta$$ comment from Dusty,which just cost him a sale. Then Lonnie has to chime-in to basically cut me down for not having a GEN 7. And three weeks after the original post he comes in with the above! This board has changed from what it used to be years ago. Yes I just bought my GN in May of this year but I have been a member since 2002 and was still visiting before joining. Now there is a bunch of BS and bitching, whining and finger pointing and name calling between alot of vendors. I know that you have businesses to run, but PLEASE just go back to helping the TR COMMUNITY, sales WILL follow customer service.There are ALOT of talented people here on the boards with the know-how and experience to help, they just choose not too or try to make someone else look bad to others. The vendors need to work together without taking a cheap-shot at the other. I have spent around $7,000.00 on my car since June and most of it went to Jack Cotton, not because he was the cheapest,I never price shopped, I never asked for any discount whatsoever, it was simply customer service, and it remains still. Having your vendor offer a cell number to call for ANY issues is priceless in my book.
Thanks for listening to my rant.This WAS after all MY thread.
Bryan
Now back to the regularly scheduled @#$%
Bryan
Bryan I do apologize for posting crap on your thread. Nothing wrong with your XFI it will get the job done. Not cutting you down in anyway you bought a good unit. I was a little heated with Jacks post and should have responded an let it go. I would be more than glad to help if you would like to give me a call. There are many good guys on this board also that can help. I am sure Jack will get you taken care of.
Phoneguy,
Sorry for taking your thread off track. I should have known what would follow.
Jack is a top-notch guy and as suggested many times, he will take good care of you. Hope you were able to find some useful info through all this.
All you have to do is pull the bowls off and change jets.
