New Install-Aerospace Rear Disc-Pro street Model
jmendlik
Just finsihed installing Aerospace Rear disc brake setup on my 86T. Install was straight forward-I did have to trim the housing some to make it fit but all is good. Went with slotted/drilled/zinc plated option on the kit. Got from Hartline for $575 and had it within 3 days of ordering.
Nice. For that price I'm not sure why everyone doesn't do this!!!
Beautiful. What size are the rotors?
Pro Street Rear dics brake kit
KIT INCLUDES:
• Billet Aluminum 4 Piston Calipers
• Billet Aluminum Mounting Brackets
• Grade 8 Hardware
• Billet Aluminum Hats with multi bolt patterns
• Screw on Dust Caps
• Brake Pads
• 11 3/4” Diameter .81” thick Cast Vaned Rotors
That's awesome for the price. If you can go into detail about what exactly had to be modified, I might be purchasing.
Install instructions
-removed rear end cover
-pulled out c-clips and removed axels
-removed entire drum brake set up inculding backing plates
-only thing left is the axle housing showing
-had to trim (sawzaw) of a portion of the housing to make the aluminum brakcet fit onto the housing end.
-Drilled 2 new holes into the housing and mounted the aluminum bracket.
-Mounted rotor/centered caliper/install pads/bleed brakes/filled rear end up with fluid
-I have 17" wheels so no clearence issues here
Done
rear disc
They are the "Pro Street" kit not the drag race version so I see no issues with usage...my car is not a daily driver...
weight savings
I did not use a scale but having the drum/brake shoes/backing plates/wheel cuyliders and all hardware in my hand vs. the Aerospce rotor and billet aluminum caliper I would say there is a differnce in weight for sure...I'm guessing 10lbs each side....just a guess...
JM
emergency brake
This system does not. they do make one with that but that system cost $895
shock relocation ?
No Relocation Of Anything....nerver Even Touched The Shocks...only Real Mod Was Trimming Of The Axle Housing.
Jm
Looks like Baer finally has some competition on the rear brakes. Looks killer!
Conrad
