New stroker motor track times!
WSLN 6
Powered by Murphy's Law
Went to our local track with the rebuilt stroker motor,very promising...
Combo is 70BB turbo,2210/215 roller,.020 Diamond pistons,SCAT rods/CAT crank,DR's,3800 lbs with driver
First run
2psi launch and 18psi boost. I don't have a cage,so I had to get on the brakes early. It ran 11.85 at 77mph with a 1.70 60ft.
Second run
4psi launch and 16psi boost. Ran 11.9 at 82mph with a 1.62 60ft
I wonder what that run would have been full out! LOL. I was under a ver watchful eye at our local track.....
The track was not prepped, air was around 4000 feet.
Bottom line,they stroker was a pain in the ass to build,but the results speak for themselves.:biggrin:
should have gone all out on the last pass just to see where your at. so far those #'s look nice.
I would like to know what type of head gaskets you are useing ,,,the thickness,,,, and the bore of the gasket,,,,,THANKS
First run
Second run
At first I didn't understand the mph. I guess you lifted at the end. Nice run.
what were the rest of the slip numbers ?, with 1/8 times figuring 1/4 et isnt that difficult
Unfortunately, no 1/8th mile timers at the track...
I am using the RJC steel gaskets, have for the last 5 years. I love em so far. They are .029 compressed. I think I would be close to 247ci or so. I used some 5.970 rods that were a tad long, so I ended up milling the pistons down .015. Compression would be more than stock I would imagine.:wink:
