Nitrous for spooling using XFI
Razor
Forum tech Advisor
Staff member
Anyone doing it?
Tips?
I use my first output for my shift light.. dont know if I may have to change that around for this. Would love to be able and do it .. maybe setup first stage power adder activation at 100% TPS 2800 RPM's and shut it off at 3500 RPM's..
Guess not a good idea to bounce it off the two step :eek:
Thoughts?? Its just a wet meth 35 shot ;)
Bamford said to.... J/K
Anyways its only to be used in TSM rite?
So this is what I did.. I setup my first power adder to come on at 2500 RPM's.. then I set my Aux 2 output(map/tps) to shut it off at 10 PSI. I now can trim at what boost level I want it to shut off at.. or what RPM I want it to activate at.
At 4 PSI it starts to flow alky through the wet portion.. only does less than 5% correction on the 35 shot.
I still have a push button for the "Just In Case" the need arises situations :D
HTH
