Dusty Bradford
- May 24, 2001
Com'on. Really? I'm not as naive as you might think.
When was the last time you heard of someone pumping out 1600 hp with 1.835" intake valves? Even I know that if a sim told me I might achieve 1600 hp with 1.835" valves, it would be a gross error. Do you seriously believe it's possible, Dusty. Seriously? I thought you knew your stuff.
You are saying in your other post that your intake and header design has made a head that flows 210 on the bench, flow 310 in the real world. Is the 310 at 28psi of intake pressure or is the sim calculating this would be the flow at 28in/h2o. You can trick a flow bench by raising the testing pressure.
I'm not sure where the 1600hp comes in at. You had mentioned your heads were a restriction compared to modern day heads. I'm just pointing out that if the sim is correct, they are not a restriction. So I'm wondering why you feel they are a restriction when the sim tells you they are not?
