Terrance P. Perryman
- Dec 28, 2012
I am using a Melling P20i Thrust Plate on my front cover and I developed an oil leak on the bottom (brown) gasket that fits between the thrust plate and oil filter housing. My question is has anyone ever used one of the regular paper gaskets that comes with the oil pump kits in this location? The only difference that I can see is the regular gasket has a larger hole opening to support the gears and the brown gasket does not. Thanks...
